Whatsapp Multi agent AI knowledge base
I just installed the latest 2.0 version:
I set everything for IA agent, but I have an issue to add the AI source article.
Nothing happen when I click in the field, and if I manually add the ID in the field, it is not saved.
18 hours 12 minutes ago - 7 hours 59 minutes ago #1 by Chris Tian
Last edit: 7 hours 59 minutes ago by TemplatePlazza.
  • Posted by TemplatePlazza (5395) Offline
Hi Chris,
You just need to type the article name, then the option will show up below the field for you to choose.
Please see this video: www.dropbox.com/scl/fi/ohj3964lgyqawiopd...dk&st=xgho2k8z&raw=1
15 hours 15 minutes ago #2 by TemplatePlazza
Got it, everything works fine. Thanks a lot.
8 hours 1 minute ago #3 by Chris Tian
No problem, glad it works
7 hours 59 minutes ago #4 by TemplatePlazza
