Hi Phil, if you want to translate the entire interface, you can translate the language file located at /language/en-GB/en-GB.mod_whatsapp_agent.ini into your preferred language.
However, if you are referring specifically to the greeting message settings, the recommended approach is to create multiple WhatsApp modules (for example: WhatsApp Lang A, WhatsApp Lang B, WhatsApp Lang C). Then, customize the greeting text in each module according to its language, and publish each module for the corresponding language filter.
10 months 2 weeks ago #2
