Minifrontpagepro 3.1.3: carousel bug when duplicate
Minifrontpagepro 3.1.3 has an issue when it is inserted multiple times on the same page.As you can see here,
www.infoparigi.it/arrivare/a-parigi-in-auto
the first carousel instance can move, but it shows three control icons instead of one. In the other instance, the carousel appears static and is displayed incorrectly.
8 months 4 days ago - 8 months 4 days ago #1 by nome
Last edit: 8 months 4 days ago by nome.
Hi, I'm sorry but I couldn’t find the issue on the page you provided. Could you please explain in more detail how to reproduce it? For example, how many modules have you published, and which MiniFP themes are you using?
Multiple-instance carousel mode should work correctly, as you can see on the demo page demo.templateplazza.com/joomla/index.php...odule-carousel-theme
Also, maybe you can also checking your template. When I opened your page, I noticed several javascript errors in the console that appear to be caused by the template.
8 months 4 days ago - 8 months 4 days ago #2 by TemplatePlazza
Last edit: 8 months 4 days ago by TemplatePlazza.
