When I use the Chatbot with Google Gemini, it will work great. Google has requested the API to be restricted, but when I use my website e.g sample.com/* chatbot gets 403 errors and stops working. This restriction works with other API enabled app (maps etc) it is only the chatbot that fails.
Is there a solution, or does the chatbot require an unrestricted API?
6 months 4 days ago #1
by Peter Haseler
