Is there a way to prevent the introtext formatting from being stripped?
Hi, I have two instances of the MinifrontpagePro module using the Carousel theme. Is there a way to prevent the introtext formatting from being stripped or removed?
I’d also like to keep the link assigned to the image (which currently leads to the article itself).
Perhaps this is possible by overriding the template.
Best regards
3 months 4 weeks ago #1 by theant
Hi theant,Yes, both of those can be done through a template override. After you've created the template override, find this line:
echo HTMLHelper::_('string.truncate', strip_tags($item->introtext), $introtext_truncate);
Replace it with:
echo HTMLHelper::_('string.truncate', $item->introtext, $introtext_truncate, true, true);
For the image link, simply find this part :
<a href="<?php echo $item->link; ?>" ...
and replace it with :
<a href="<?php echo $thumb_img[1]; ?>" ...
3 months 4 weeks ago - 3 months 4 weeks ago #2 by TemplatePlazza
Last edit: 3 months 4 weeks ago by TemplatePlazza.
