No article title on the images [Minifrontpage]
With Minifrontpage Pro is it possible to hide the article titles and make the articles accessible by clicking on the image?
Thanks for your answers.
3 months 2 weeks ago - 3 months 2 weeks ago #1 by Theomart
Last edit: 3 months 2 weeks ago by Theomart.
Hi, yes, it's possible by using a template override. You can follow this video
Could you let me know which theme you're using? So I can recommend the override code for your theme
3 months 2 weeks ago #2 by TemplatePlazza
I'm using a template created with Template Creator CK
www.template-creator.com
3 months 2 weeks ago #3 by Theomart
Hi, template overrides are a core Joomla feature, so you can create template overrides regardless of which Joomla template you're using
3 months 2 weeks ago #4 by TemplatePlazza
So... what change needs to be made?????,
3 months 6 days ago #5 by Theomart
Could you let me know which minifrontpage theme (carousel, default, newsy, etc..) you're using? So I can recommend the override code for your theme
3 months 6 days ago - 3 months 6 days ago #6 by TemplatePlazza
Last edit: 3 months 6 days ago by TemplatePlazza.
