Mini K2 problem
Hello.
I have installed the Mini K2 module in my attempting web (I´m still building it) and i would like it to looks like the demo site :D
But when I try to show it in the simple mode what I obtain is this:
www.jiq-rseq.org/index.php/es/actividades
I have tried to modify the module position and jquery configuration but i couldn´t obtain anything.
Could somebody help me.
Thank you
13 years 8 months ago #1 by rdelagueto
From what I can see on your header section that you've got 3 JQuery libraries loaded there. From your expose, modalizzer plugin and one from I don't know, calling external Google CDN jquery.
If there's an option to de-select jQuery from Expose and modalizer parameter, then you should do that first to try.
13 years 8 months ago #2 by erwinschro
Hello.
Thanks for the reply. I´ve check every module and component and i have tried to select those in a way that only one jquery library is loaded, but the result in the same.
I tried the module in the default template beeze2 and worked properly.
Do you have another idea?
Thank you in advance
13 years 8 months ago #3 by rdelagueto
Ok what i can see now the only problem in there is a 'wrapper' module where you published Mini K2 is only limited to have only 200px width.
<div class="block module mod-145 clearfix" style="opacity: 1;">
.block {
width: 200px;
Try publish it in a wider module position then...
13 years 8 months ago #4 by erwinschro
Dear erwinschro, thank you for you efforts
I have assigned the module to a position that can fit the whole screen. I have also tel the module to have a 600px width.... no result :(
Rafa
13 years 8 months ago #5 by rdelagueto
One more question. My template is responsive, could it be a reason for the module to fail?
13 years 8 months ago #6 by rdelagueto
