Responsive slider not working properly
- Posted by marceff (11) Offline
I have purchased Responsive slider and I also installed. For a while it worked fine, then after few hours turns working fading pictures no matter which effect you select. I tried to disable all modules, I did check about other jquery, I also check questions in thi forum, but I couldn't find any solution.
Would you help me? Thanks
PS If you like to give a look to my url, please go to www.socialsailing.eu
13 years 8 months ago #1
by marceff
Strange if this only happen after few hours...
I can see it's working fine now...but I can't sit and take a look at it until the next few hours just to see it start to begin fading...
13 years 8 months ago #2
Thank you for your replay.
It happen that if I look the site from my Mac in my office, it works fine but if I do it from a MacBook at home the slider works only fading no matter what kind of setting you do.
There must be something related to a plugin that may not present in the MacBook. Does the slider need Flash player last release?
13 years 8 months ago #3
by marceff
Mmm...we should wait Andy - my co-worker to take a look at this on his MacBook then Marceff...
13 years 8 months ago #4
Hi Marcheff, Responsive Banner Slider doesn't need flash player installed. It's pure jQuery + CSS effects. Btw I have checked on with my MBP with chrome anf firefox and the animation works properly. I have uploaded the screen record in here d.pr/v/HgGN Please have alook
13 years 8 months ago #5
by andy
