Mini Front Page Thumbnails
I cannot get thumbnails of images to show in the otherwise functional and attractive Mini Front Page module. I am using V2.1.2 of Mini Front Page in a Joomla 1.7 installation.
I have examined the folder images/minifp and found that it had no owner. I have downloaded it and uploaded it using filezilla to give it an owner and have set attributes to 777. All of which made no difference. My images are always right at the top of articles I wish Mini Front Page to represent.
Any help to get the thumbnails working would be gratefully received.
14 years 1 day ago #1 by grajsmith
Hello grajsmith,
I've tried to check your site, but i can't see the minifrontpage.
Can you tell me where i can find it?
14 years 1 day ago #2 by ronysyz
Hi ronysyz,
www.frontiersvcs.com/index.php/vacanciesc
But you will have to register first. I'm sorry that's cumbersome in this instance. Then, Mini Front Page is displayed in the far right column. Thank you for your input in advance if you are prepared to go through the very simple registration process. Also my apologies I should have indicated this from the off.
Best regards,
Graham.
14 years 1 day ago #3 by grajsmith
Would be nice if you create an account for me and give it here
14 years 1 day ago #4 by ronysyz
Sure,
Username Example
Pword xxxx
14 years 18 hours ago #5 by grajsmith
I've checked your site and found the reason of your problem. It because you use images that contains spacing on its file name, for example "job header pic4.png" and minifp is unable to generate thumbnails for it
The solution is you should be change all of your image names and removes all spacing on its filename,
you can use "_" or "-" for example: job_header_pic4.png or job-header-pic4.png
Hope this helps
14 years 12 hours ago #6 by ronysyz
