Help with launchtime on Joomla 3
- Posted by lulo (2) Offline
Hi, i just download the launchtime template and after installing it i just get the next message at my website.
Fatal error: require_once(): Failed opening required '/homepages/25/d454478087/htdocs/Joomla/templates/launchtimeDIRECTORY_SEPAATORframework.php' (include_path='.:/usr/lib/php6') in /homepages/25/d454478087/htdocs/Joomla/templates/launchtime/index.php on line 16
Maybe is an obvious mistake but i can't solve it, i am new at joomla as you can see, please could you help me with it? if you need more information please just let me know
13 years 8 months ago #1
by lulo
Hello Pepeto
Can you manage to edit this file
/templates/template/launchtime/index.php ?
If you do, please edit the following line 14
into
Hope that fix the error. Let us know then.
13 years 8 months ago #2
define( 'DS', DIRECTORY_SEPAATOR );into
define( 'DS', DIRECTORY_SEPARATOR );Hope that fix the error. Let us know then.
Thank you very much, i just edit the line as you said and it just fix the problem.
Again, thank you very much!!
13 years 8 months ago #3
by lulo
