Add to cart button not working
Previously we spoke about the Add to cart button not working see your site details belowand you said it was my server permissions the server support want to know
We need the following information from you regarding virtuemart:
What settings are required for it to work?
What versions of sql, php,etc are required by the version of virtuemart that you wish to run?
What permissions are required by virtuemart?
As soon as you can provide these details we can compare them to the server and adjust where necessary.
can you help virtumart 2 thats all I know.Thanks
13 years 7 months ago #1 by matthew
Hi matt,I'm not really sure about the server requirements but I think it just a standard requirements. You can find the more complete information at virtuemart.net.
But I think you should ask your hosting provider first whether they fully support joomla or not, because as you can see yourself, when you installed virtuemart alone the 'Add to Cart' button still didn't work.
13 years 7 months ago #2 by andy
