Button background not changing
Hi guys,
I like your MiniFrontpage plugin, and I use it!
I have a problem with the color of the READ MORE button.
I selected the default layout type in the module.
then i change the css located here:
/modules/mod_minifrontpage/themes/default/assets/css
from
.minifrontpage-default a.mfp-readon {
background: #7BA428;
to
background: #6975a5;
but nothing changes. (I pressed F5 and reload page many times).
I also tried to totally delete the CSS file from the default and it does not change anything. It is like if the CSS was coded somewhere else.
I change all the CSS in all themes folder to the correct background color... but no luck
Please could you guide me?
Thanks for your help
Nic
13 years 6 months ago #1 by jbesclapez
Hello Nic
It could be readmore link style is overriden by something.
Is it possible for us to take a look at your page where you publish the minifrontpage?
13 years 6 months ago #2 by erwinschro
