Carousel Banner Parameters ??
- Posted by Ken (1) Offline
Is there a way to changes the type of transition or the transition speed of the Carousel Banner ? Can I remove the forward and back buttons and just have the banners rotate in order ?
13 years 6 months ago #1
by Ken
This module is basd on jCarousel script from the link below. You can change the default configuration from mod_carousel_banner.php
you may read their documentation what are options available for the animation speed, easing or transition. Not sure if we could remove the navigation arrow though.
13 years 6 months ago #2
jQuery("#mycarousel'. $cb_mod_id.'").jcarousel({
auto: 3,
scroll:1,
rtl:false,
visible:1,
wrap: \'last\',
easing: \'BounceEaseOut\',
animation: 1000,
initCallback: mycarousel_initCallback
});you may read their documentation what are options available for the animation speed, easing or transition. Not sure if we could remove the navigation arrow though.
- Posted by wekko (1) Offline
It's better if you don't modify the module / script, best option is just hide it with CSS:
.nbs-flexisel-nav-left, .nbs-flexisel-nav-right {
display:none;
12 years 9 months ago #3
by wekko
display:none;
