Page Peel not seeing bg.png file
I installed this and can't get it to see the bg.png or bg-dark.png file. Developer tools shows:
GET montesanobrewery.com/modules/mod_pagepee...ssets/bg-dark.png%20 404 (Not Found)
I'm somewhat new to all this, and I see that %20 means the space bar. However, I can't seem to figure out what this means. The file IS there amd perms are correct.
ANy help would greatly be appreciated.
-Jay
13 years 6 months ago #1 by Jay Reeves
is it possible for you to upload the following file below to overwrite what you have in there?
Please unzip it first to find out default.php file then upload it to /modules/mod_pagepeel_banner/tmpl/ folder.
Let us know if that works.
13 years 6 months ago #2 by erwinschro
That fixed it! Thank you very much!
The only difference I saw between the files was a space removed from one line - does this ONLY apply in certain situations, or can that fix be applied to all installations?
13 years 6 months ago #3 by Jay Reeves
Nop, this fix can be applied to all installation hopefully.
we have updated the downloadable module file too.
13 years 6 months ago #4 by erwinschro
