mini k2 problems
I'm using your mini k2 module on a joomla 3.0 site. However, it's not working like your demo.
Select sub-template is set to "simple"
1. When I hover over an image, the rest of the other images don't fade out (as in your demo).
2. If I set the "Item count" to 7 or less the images show, but if I set it to more than 7 the images disappear.
14 years 2 weeks ago #1 by tmld
Hello tmld,
Can i see your live site for this case?
14 years 2 weeks ago #2 by ronysyz
14 years 2 weeks ago #3 by tmld
You might also notice, that the images show for a split second and then disappear!
Thanks.
14 years 2 weeks ago #4 by tmld
what about if you try to disable the others module, and let wee see...
14 years 2 weeks ago #5 by ronysyz
Ok, I turned off all the other modules, and still have the same issue. But, now I have narrowed down the problem, somewhat...If there's an article without an image, it won't work, otherwise, it works.
So, basically it keeps showing the images of articles (for a split second) until it hits an article without an image, then all the images disappear.
14 years 2 weeks ago #6 by tmld
