Xtypo Themes to be Selectable
hey guys have this setup and working fine in JCE, although configured slightly differently due to wanting to have it enabled globally and independant of any templates installed or used.
I was wondering if it was possible to add an option when applying the styles in the editor there could be an option to select the theme to use, as well as the class being applied. That would be awesome, as we could mix and match even within the one document of different styles ... which would be pretty cool :)
Hopefully, this can be something for a future release, thanks.
13 years 6 months ago #1 by Max Lynam
Hmm, nice idea maxinam :) will definitely consider it
13 years 6 months ago #2 by andy
That'd be absolutely awesome ... would suggest combining all css files for this, as would then just be a single (minified) file to load all from in PUS version ... just need to to something like adding the theme to the icon class.
Also, when Bootstrap3 comes out, the icons will be font based, so could include those too, or pull from JUI when they update to it.
13 years 6 months ago #3 by Max Lynam
Ok :) Thanks for the suggestion
13 years 6 months ago #4 by andy
