Serious problems with the category dropdown on mobile.
When browsing on mobile and select a category the dropdown does not stay attached to the finger can select a sub-category and open. By this makes navigation useless mobile and tablets. This is a very important problem since today is basic.
Please. Can you give me a solution? I think the problem is in file called superfish him.
Thank you.
13 years 6 months ago #1 by Javier
Hello maxss, Can you tell me what extension you're talking about?
13 years 6 months ago #2 by andy
I mean Hello realemnte Deal Plazza template. I use Joomla 2.5
13 years 6 months ago #3 by Javier
Hi, really I mean the Deal Plazza template. I use Joomla 2.5
13 years 6 months ago #4 by Javier
Ah ok. Just to make sure, so did you mean that you can't select the submenu items when the parent menu is tapped?
13 years 6 months ago #5 by andy
Also Can you share your website URL so I can take a look?
13 years 6 months ago #6 by andy
