Sequence Slider type style 1 customization
- Posted by rottenberg (60) Offline
hello
I want to use Sequence Slider type style 1.
2 questions :
thank you for advices
best regards
Michel
13 years 6 months ago #1
by rottenberg
2 questions :
- Some banners don't have any hyperlink. Is it possible to avoid the display of read details ?
- The site is french speaking. Is it possible to translate the 'read detail' in french (voir les détails) ?
best regards
Michel
Hello Michel
I think that possible to remove those links which you can do it inside
/mod_responsivebannerslider/tmpl/sequence.php
find out each anchor tag there and comment out them
Also to translate Read more you can do that from inside the mod_responsivebannerslider language file. Copy then rename the English version of it en-GB.mod_responsivebannerslider.ini to French language folder. then translate from there.
13 years 6 months ago #2
