Carousel background
Is there any way to make the background of the carousel transparent instead of white?
See my usage of it at:
fireworksland.com/index.php
Thank you!
13 years 6 months ago #1 by bw92116
It looks like you have found it...
13 years 6 months ago #2 by erwinschro
Thank you for your reply. I am looking for the space between the ads to be transparent, not white, so that in between each ad you see the blue background. Is there any way to make the container that holds the ads transparent?
13 years 6 months ago #3 by bw92116
I don't see carousel banner installed on your website. Did you unpublish it?
13 years 6 months ago #4 by andy
As I said above,
It looks like you have found a solution for it...
because I see blue backround between each ad there.
@andy that's a carousel banner you see there... :)
13 years 6 months ago #5 by erwinschro
Thank you for your reply. I just now changed the flexisel.css file to have the background transparent. (Changed 100% to 0% for all colors).
Thanks for making this module.
I have it set to display 6 banners visible at a time, except on portrait orientation, only 2 banners visible at a time. The only problem is when I turn my iPod to landscape orientation. Then it shows 6 banners at a time and they are all overlapping each other.
13 years 6 months ago #6 by bw92116
