Carousel Banner won't change pictures
- Posted by tokero (2) Offline
Carousel Banner 2.2.1
Can't get it to run. It doesn't change any picture. I have tried to load jQuery from component, Google and without loading. Banners are ok (all are in same category, sticky, Publishing startdate 2012-07-24, Publishing end date 2013-10-29,size 350x160, Max impressions unlimited, track impressions yes, track clicks yes).
Site www.vaasantelinetaiturit.fi (upper right module "Yhteistyökuimppanit")
Module settings are:
Load JQuery: No
Count : 7
Banner Client: "my banner client"
Category : "MyCategory"
Banner width : 350
Banner height: 160
Search By Tags : No
Randomise : Sticky, Randomise
Target: Open in new window
Alternative Layout : default
Responsive Layout Options
Visible items :1
Visible items in Portrait : 1
Visible items in Landscape : 1
Visible items in Tablet : 1
Animation speed : 1000
Autoplay: Yes
Autoplay speed : 3000
Pause on Hover: Yes
13 years 5 months ago #1
by tokero
Load JQuery: No
Count : 7
Banner width : 350
Banner height: 160
Search By Tags : No
Visible items :1
Autoplay: Yes
Pause on Hover: Yes
Hi, Can you try to switch your template to default one (beez or etc) to check whether this is related to a template problem or not
13 years 5 months ago #2
by andy
Beez 20 and Light Breeze Blue tested, didn't work. This tempalte has worked before without problems. Site has few admins and of course none has done changes that should affect like this
I updated Carousel to latest version (before posting here) to see if that would help but it didn't.
13 years 5 months ago #3
by tokero
- Posted by Yosh (2) Offline
I am having the same issue in J3.2, the module does not autoplay whatsoever... Any fix?
12 years 11 months ago #4
by Yosh
Ok, I just noticed it is because I had to select the flexisel layout on the module configuration. I was using the default layout.
12 years 11 months ago #5
by Yosh
