Minifrontpage module
When i download the the minifrontpage module zip (mod_minifrontpage_unzip_first.zip) and then try to unzip it gives me the following internal error.
The compressed zip folder is invalid
I have tried to donwload many times and have tried windows zip, stuffit and winrar to unzip
13 years 5 months ago #1 by Abu
Hi Please try to redwonload it again, or use other browser to download it
13 years 5 months ago #2 by andy
Thanks I downloaded and installed succesfully using firefox. When i display the module i get the following error:
Notice: Trying to get property of non-object in /var/www/clients/client1/web6/web/modules/mod_minifrontpage/mod_minifrontpage.php on line 115 Notice: Trying to get property of non-object in /var/www/clients/client1/web6/web/modules/mod_minifrontpage/mod_minifrontpage.php on line 116 Notice:
Notice: Undefined property: stdClass::$thumb in /var/www/clients/client1/web6/web/modules/mod_minifrontpage/themes/default/tmpl/bottom.php on line 78
Anu advice??
13 years 5 months ago #3 by Abu
Do you know what version of PHP used on your server?
13 years 5 months ago #4 by erwinschro
hello,
i have the same problem after i changed my provider.
the formally server was php 5.2.17 and i had no problems, now i have php 5.3 and get the same error like abub007
is there something to change in the php file or do you have any other solution?
thx
wudry
13 years 4 months ago #5 by hudry
Hi Wudry
can you re-install it using the one attached with a fix? and let us know the result if the error is gone or not
(I attach a J2.5 version...let us know if you need a J3.x version)
thanks
13 years 4 months ago #6 by erwinschro
