Mini K2 masonry layout
The simple/masonry layout doesn't look like the demo website. The articles are supposed to line up vertically with no spaces/breaks, but my layout forces the articles into even rows. I'm not sure how to describe it best, so I attached a screenshot.
13 years 11 months ago #1 by Dayna Holliman
I had the Load JQuery option checked. I selected No and it works fine now!
13 years 11 months ago #2 by Dayna Holliman
Hello frugalfashioning,
Sorry for late respond, glad to know the problem is already resolved now
And about the Jquery option, when you use for Joomla 2.5, sometimes you need to enable or disable it. It depends on your template or the other extensions you use.
13 years 11 months ago #3 by ronysyz
