Social Media Icons not working on LaunchTime
I have no problem getting the social media icons on the launch page, but when you click on one (Facebook for example), it goes to www.mysite.com/myFacebookURL. It does the same thing for Twitter & Google +. How do I remove mysite.com from the social media links?
13 years 5 months ago #1 by Scott Potteiger
Have you check them on the LaunchTime template parameters and fill them with full URL path?
13 years 5 months ago #2 by erwinschro
I'm not sure what you mean by parameters, but when I open up the LaunchTime template Options, my social media URLs are correct. As an example, for Twitter I have www.twitter.com/StayInTouch_GC. Is there somewhere else I should be checking the template parameters?
Also I have the custom HTML code to add the "First Name" box from MailChimp, can I add this in the LaunchTime template through one of the CSS files?
13 years 5 months ago #3 by Scott Potteiger
Why did you downvote me? i was just want to clarify before...
13 years 5 months ago #4 by erwinschro
Sorry it was an accident, so I gave you a positive vote on this response. I appreciate the fact that you tried an answer. Do you have any other suggestions?
13 years 5 months ago #5 by Scott Potteiger
Can you post a live URL so we can take a look at the generated HTML codes of your site?
13 years 5 months ago #6 by erwinschro
