Dropmenu problem in deal plaza
hello, I have a problem with the dropmenu, going down the page, the menu does not remain fixed, how can I solve? I have disabled jquery on k2 and of virtue
13 years 5 months ago #1 by Pietro
Can you post a live URL so we can take a look?
13 years 5 months ago #2 by erwinschro
13 years 5 months ago #3 by Pietro
Can you disable jQuery from responsivebanner slider module? and see if that helps
13 years 5 months ago #4 by erwinschro
ok, it works.
thanks
there is a translation in Italian?
There is a detailed guide to configure the deals?
thanks
13 years 5 months ago #5 by Pietro
Glad it works then
I'm afraid we don't have a translation in Italian or any other language but it's easy as you just need to provide an italian language file for the template and extensions used like K2 and Virtuemart.
For the start you can find the following English language file
/language/en-GB/en-GB.tpl_deals_plazza.ini
/language/en-GB/en-GB.com_k2.ini
/language/en-GB/en-GB.en-GB.com_virtuemart.ini
etc
then create Italian for them and plavce it under
/language/it-IT/ folder (maybe?)
Also there's a guide inside the template package under /documentation/ folder. Hope you'll find how to configure there.
13 years 5 months ago #6 by erwinschro
