Xtypo plugin conflicts.
Good evening!
I've checked the forum but I haven't found something regard my issue.
I've installed xtypo plugin along with xtypo button.
At first, I did not recognize that it was giving me issues. It had been installed before I have started to modify the site. When I saw that the images were not loading properly, I went to the developer of the template asking why it happened. He told me then to try to disable xtypo. I've tried out and he was right, it looks like that xtypo plugin has a conflict with something else into the site.
Thanks for your attention!
Impostazione Valore
PHP attivo su Linux paas_15096 3.8.5-grsec-paas-97f0d49 #1 SMP PREEMPT Thu Apr 4 09:38:07 UTC 2013 x86_64
Versione database 5.5.30-1-log
Collation database utf8_general_ci
Versione PHP 5.4.4-14
Web Server Apache/2.4.4
WebServer interfaccia PHP fpm-fcgi
Versione di Joomla! Joomla! 3.1.1 Stable [ Ember ] 26-April-2013 14:00 GMT
Versione piattaforma Joomla! Joomla Platform 12.2.0 Stable [ Neil Armstrong ] 21-September-2012 00:00 GMT
User Agent Mozilla/5.0 (Windows NT 6.1; WOW64; rv:21.0) Gecko/20100101 Firefox/21.0
13 years 5 months ago #1 by Bizzosrl
Your admin account provided is not working so I'm not able to look at the problem.
Can you clarify more what images which were not loading properly?
13 years 5 months ago #2 by erwinschro
Every image in the articles where I'm using xtypo.
If you go on "Riscaldamento" -> "Caldaie a Condensazione" or "Caldaie a gas" you may see that the images of these products aren't complete, but somehow "cut". If I disable xtypo, everything goes fine. I've set the entire 2 articles on xtypo.
I'm trying again to give you the infos, maybe the latest time I did not write them properly!
Thanks for your help and time! ;)
P.S.: I haven't tinymce, but only mce. Maybe the issue is done by span[class]? I don't think I could have add it properly.
13 years 5 months ago #3 by Bizzosrl
Hi Bizsosri, I've checked it, it because the image you put inside the blockquote is floated to right.
Please try to add this css code anywhere on your template css :
.xtypo_list ul, .xtypo_list_left ul, .xtypo_list_right ul {background-color:transparent!important;}
13 years 5 months ago #4 by andy
Thanks.
The issue was not really an issue, at work I did not see the background of the "list" option. I was seeing it completely white and it was just hiding the image under!
How embarassing!
I've added the code but "nothing" changed with the default theme. Now, I've selected another theme that I like a bit more. But I think I will do a re-work on the images soon as I don't like the white background they have!
Thanks again and sorry to have bothered you!
Monica
13 years 5 months ago #5 by Bizzosrl
No problem Monica :) Glad to know it's resolved
13 years 5 months ago #6 by andy
