menu over k2
When you log in and click on Add a new item in the k2 category or edit item in the front end a k2 pop up comes up and you make an article select a category and you try to edit extra fields to change the price the bopup goes up behind the menu The menu covers the save button. The sticky menu is good but this is a major drawback see attached save missing.png
Test for your self at Your site details
Is there a way we can make it disappear when you click the edit button this would be a good feature and fix a lot of problems?
13 years 5 months ago #1 by matthew
13 years 2 months ago #2 by matthew
Matt,
What version did you use? This should have already fixed in the last version
13 years 2 months ago #3 by andy
How do I get the latest version ? which file do I upload?
13 years 2 months ago #4 by matthew
You always be able to download the latest file at :
www.templateplazza.com/products/design/j...ument/16-deal-plazza
13 years 2 months ago #5 by andy
I have type="template" version="2.5"><name>deals_plazza</name><creationDate>2012-03-08</creationDate>version which file do I put or change to fix the sticky menu problem?
13 years 2 months ago #6 by matthew
