Miniticker Does not show the correct Created Date of an article
- Posted by Volgana (1) Offline
In the module options you have a check if we want to show the Created Date or the Modified Date of the articles
Modified Date works fine but if i check Created Date, is shows 01/01/1970 in all articles.
13 years 5 months ago #1
by Volgana
thanks for the info...yes that would be a bug and we will look into it a.s.a.p
13 years 5 months ago #2
- Posted by vlade (1) Offline
- Posted by Matthias (2) Offline
hello,
for me it is not working with the new version. Downloaded today v1.2
what can I do?
12 years 3 months ago #6
by Matthias
what can I do?
