MENU2PANEL
- Posted by Demetris Stylianides (10) Offline
I have installed the menu2panel module as described in the documentation. It works perfectly both on desktop and tablet. However, it is permanently on. I thought this was supposed to come into play when on a tablet or when you resize your desktop screen size. Please help (Joomla version 3)
13 years 4 months ago #1
I am currently setting up the website and that is the reason for the placeholder text. I had to add a second menu on the side (position 7). However the original menu is gone!
www.seminarscyprus.com/
13 years 4 months ago #3
Mmm that's why I confused at first ... after seeing it on your live url, it looks like you still use the previous version of menu2panel.
Please re-download it as we have change the codes inside the module and hopefully that will be fixed your current issue.
do let us know then after you re-install it.
13 years 4 months ago #4
OK new version installed. Now main menu works on the desktop version while the mobile menu is hidden. Upon resizing, the mobile menu comes into play and the main menu is hidden. This is very good and it would have been even better if the mobile menu didnt get hidden behind the home page banner. I guess that is a bug you should fix on the next issue.
Mobile menu works on the iphone as well with the same problem with the banner as stated above.
The very strange thing is that it doesnt work with my ipad 2 for some reason nor with ipad mini neither with ipad 3. On these tablets i get the main menu version. Any ideas?
13 years 4 months ago #5
@Taxgreko2 Isn't it looks weird if the menu displayed on ipad because browsers on ipad are considered as a fully functional browser not a minimal browser (browser) just like mobile devices have?
13 years 4 months ago #6
