Page Peel changing position
Im facing a strange issue. I finally managed to place the module in a position (sidebar in my template) but it happens something weird, suddenly the module will display in the sidebar position instead of the left where is set up.
If i clear caché the module shows correctly in the top left.
Any idea?
13 years 4 months ago #1 by Manu
Btw, website is: comenaranjas.com/es/
13 years 4 months ago #2 by Manu
Could it be an issue with the caché? I use 120 minutes conservational at global joomla config.
Joomla 2.5.11 and module settings:
Load jquery= No
Layout type= jquery
Peel direction= left
Auto open= disable
the small image to 80 and big to 300 px, everything seems to work fine except the module randomly shows in the right sidebar (the position selected) instead of the left corner.
CSS class= yagSpecialChromesNone
Yangendoo framework suffix that hides borders
13 years 4 months ago #3 by Manu
I don;t see any problem you mentioned above...
it could be a slow internet connection problem so your jquery library call failed that might cause pagepeel not positioned as it should...
13 years 4 months ago #4 by erwinschro
Hi thanks for reply
Nope, thats not the issue, my connection is pretty decent + it happened in 2 pc's in different locations.
Even more strange is the fact that at the same time it was showned correctly in one PC with a big screen (top left position) and incorrectly in a laptop with a smaller screen (module position).
When that happens the only solution is to clear caché and then it displays fine again.
Weird eh? If it happens again Ill make a screenshot although I don't know if that would be of any help.
13 years 4 months ago #5 by Manu
Hi, I think I found the issue, at least how to replicate it.
It happened when we added a product to the cart and went back from the checkout.
So it could be a js conflict with Virtuemart or the yagendoo framework. I personally think is the effect of the add to cart our template uses.
I have placed the module just at homepage to avoid the issue.
13 years 4 months ago #6 by Manu
