Page Peel module position
- Posted by kevie (4) Offline
hi im falling to put the page peel on the upper right corner, how do i out it there i don't:( have module position in that area THNAKS
13 years 5 months ago #1
by kevie
HI, You don't have to have a module position on the upper right corner. It will be automatically placed at the upper right corner of your website
13 years 5 months ago #2
by andy
thanks for the reply i have tried putting it into other module positions but it just shows up on those positions not on the corner, i have even tried without any module position but it will not show up. what im i doing wrong
13 years 5 months ago #3
by kevie
www.sciencemathzone.com/ It seems if i enable flash on "Choose Layout Type" it will go there but on jQuery it will not show, i want to use jQuery not flash
13 years 5 months ago #5
by kevie
It seems your template already have a built in jQuery lib, so it is likely just a multiple jQuery load problem. Please try to disable jQuery plugin from the pagepeel backend.
13 years 5 months ago #6
by andy
