System message
- Posted by HAMADENE (33) Offline
the popup system message (from system.css file) was working fine, but now it doesn't want to close on click.
You can see what I'm talking about going to : www.site-de-petites-annonces.fr and click on "Votre compte" (top menu) or "Vos annonces" submenu of "Votre compte" and you should see the orange popup.
Regards.
13 years 4 months ago #1
by HAMADENE
Regards.
It looks like a jquery library conflict there. You have loaded at least 3 jQuery library
Can you first de-activate jQuery library from the following modules:
- mod_swmenufree
- mod_btlogin
hopefully there's an option for that inside their module parameter
13 years 4 months ago #2
- mod_swmenufree
- mod_btlogin
thank you very much, you helped me. It's now closing normaly.
Thanks.
Regards.
13 years 4 months ago #3
by HAMADENE
Thanks.
Regards.
