Article title h2 ?
- Posted by HAMADENE (33) Offline
I saw article title set as H2, here is the selected code :
<div class="item-page"><h2> <a href="/blog-site-de-petites-annonces/82-blog/astuces/75-petites-annonces-sur-les-réseaux-sociaux"> Petites-annonces sur les réseaux sociaux</a></h2>
Regarding SEO practices it is known that title should be H1.
What do you mind about that ?
If you're ok with H1 please tell me which line I need to change, cause I checked the template.css and couldn't find where, even puting H1 to leading.
Regards.
13 years 4 months ago #1
by HAMADENE
Regards.
It seems the code is not authorised in the message,
so you can check article title I was talking about going to my site, then "blog" link in the top menu et see articles.
13 years 4 months ago #2
by HAMADENE
Do you have any reference for that? cause it's debatable I thinkRegarding SEO practices it is known that title should be H1.
But it's up to you oif you want to change that, the h2 inside the article, you can edit them from here
/components/com_content/views/article/tmpl/default.php
and yes that's the core Joomla content component who used the h2 tag. we didn't override that inside deals plazza template
yes, in fact it is not realy "known" but debated, and I saw many webmasters wanting to change titles Heading to 1, right or wrong I still don't realy know, but I've seen that the H1 match for "categoriy" "author" (if I remember exactly) and I don't think it's a good thing to give first heading to parts that are not as new as a new article title.
I'm still wondering.
Anyway thankS for directory information in case I decide to do it.
Best regards.
13 years 4 months ago #4
by HAMADENE
Best regards.
