MiniFrontpage: Thumbnails not visible after site restore
  • Posted by Marialena Poulimenou (7) Offline
Hello all,
I recently moved my site from the subdomain to domain via Akeeba backup\restore component.
Since then the thumbnail images are not visible on the articles.
However,the frames are there and their links are active.
Please let me know if anyone has faced something similar.
Any help will be much appreciated.
P.S. There are a couple of threads with almost the same subject but unfortunately none resolve my issue. Nevertheless,if you think they are connected please feel free to merge them and accept my apologies for the inconvenience.
13 years 4 months ago #1 by Marialena Poulimenou
Well you might want to check your /images/ folder if all images are transfered well in the moving process.
13 years 4 months ago #2 by erwinschro
Erwin,
The article images have been transferred correctly, the minifp\imagecache folder thought is empty.
The odd thing is that I uninstall and install the module again but the problem persists.
Furthermore,I tried to load images from another folder and specific images from a specific folder are visible only.
Even if the article is new.
Solution: Write rights on minifp\imagecache
13 years 4 months ago #3 by Marialena Poulimenou
alrgiht then...
13 years 4 months ago #4 by erwinschro
