Image non Load Home News Display Articles Display Related Items Related Items Extended
- Posted by miki1234 (7) Offline
Hello, I bought Related Items Extended, thank you very much, I love it, I noticed that only some images does not load, an erroryou can see on this page: www.grafiksmania.com/moda-uomo/abbigliam...era-estate-2013.html. Your use template grid, I also noticed that after Publicato module does not load modules in javascript side and bottom. Could you please help solve these problems. thank you very much
13 years 5 months ago #1
by miki1234
( function.filemtime]: stat failed for /home/grafiks/public_html/images/smilies/Nina%20Ricci%20collezione%20abbigliamento%20primavera%20estate%202012.jpg in /home/grafiks/public_html/modules/mod_relateditems_xtd/image.php on line 36
Warning: imagecreatefromjpeg(/home/grafiks/public_html/images/smilies/Nina%20Ricci%20collezione%20abbigliamento%20primavera%20estate%202012.jpg) [function.imagecreatefromjpeg]: failed to open stream: No such file or directory in /home/grafiks/public_html/modules/mod_relateditems_xtd/image.php on line 44
Warning: imagesx() expects parameter 1 to be resource, boolean given in /home/grafiks/public_html/modules/mod_relateditems_xtd/image.php on line 64
Warning: imagesy() expects parameter 1 to be resource, boolean given in /home/grafiks/public_html/modules/mod_relateditems_xtd/image.php on line 65
/images/smilies/Nina%20Ricci%20collezione%20abbigliamento%20primavera%20estate%202012.jpg" alt="" title="" />)Please Log in or Create an account to join the conversation.
Glad you like the module...
Regarding those warnings, it tell us that the module can't process the image(s). This is caused by your images naming that used space between the word. i.e
can you please edit that image name so that they don't have spaces, like this
and see if that help to remove those warnings.
13 years 5 months ago #2
In my website there are 3000 articles, I can control everything manually, it takes a week ... Use of the name without spaces imagine why load JoomGallery, where JoomGallery does this automatically.
I ask please, if you can fix code without doing this work, which makes me lose a week of work.
Thank you very much for help
I apologize for my English ...
13 years 5 months ago #3
by miki1234
What do you mean by JoomGallery does this automaticallly? Did you upload your article images using JoomGallery?
Well...let's see if I can find codes that can handle reading image title with space(s)...
13 years 5 months ago #4
Thank you very much for the speed of response?
Pictures of the article load in the article and in both JoomGallery, so I do not have to rewrite the title, JoomGallery automatically takes title.
Thank you very much, I hope you can solve this problem.
Thank you very much for your patience
13 years 5 months ago #5
by miki1234
Can you re-install the mod_relateditems_xtd using this one attached? and let us know the result will you?
thanks
13 years 5 months ago #6
thanks
