Responsive banner jquery problem
- Posted by eddiez (2) Offline
I just buy and started to use responsive banner slide show. While 3d option work good, the other not work at all. Problem is with jquery I can say that much from webconsole, but I dont know how to fix.
I turned the sequence slider type now.
Could you help me please.
I would very much appreciate also explanation how to you fixed it.
With regards
13 years 5 months ago #1
by eddiez
With regards
Hi Eddiez,
Looks like this is a multiple jQuery loads problem. I found jQuery libs are load multiple times on your website and they are all loaded after the sequence javascript. Can you try to enable the jquery from the Responsive banner backend?
13 years 5 months ago #2
by andy
Thank you for quick response, unfortunetely none of those advices work ( I tried jquery turn off, from module and from google ), I have an error in web console jqeury is not a function.
I will appreciate help with this issue.
Best
13 years 4 months ago #3
by eddiez
Best
Hi eddiez, Have you tried to use this plugin : extensions.joomla.org/extensions/core-en...jquery-scripts/18327 ?
13 years 4 months ago #4
by andy
- Posted by giggimix (6) Offline
Hello I have problems with jquery too if active "Adaptor Slider".
As an alternative I'm using the Nivo Slider but how do I slow down the speed.
I need to manage a range parameter for each banner.
helppp
:D:D:D
new.salentowebtv.tv/
13 years 4 months ago #5
by giggimix
helppp
Hi giggimix, rather than commenting on other user thread, please create a new thread describing your problem. It will help us to track whether a thread/problem has already solved or not.
Regading your problem to slow down the speed, please read this thread :
www.templateplazza.com/support/forum/res...eat,-too-fast-though
13 years 4 months ago #6
by andy
