POP LOGIN configuration
I,ve download POP LOGIN module, and I want to configure:
- language (spanish, french)
- appearance of pop up window (color, style)
- botton (size, color, legend)
How can I manage these changes?. I didn´t see any configuration tool for the module or any technical documentation.
Thanks in advance.
13 years 8 months ago #1 by lolaflores
Hello Lola
Thanks for using PopLogin...
For translation, it could be easily done by creating your own language file for this module. The English language file can be found inside /JOOMLAROOT/language/en-GB/ folder. Copy the en-GB.mod_poplogin.ini to your specific language folder then edit it's content to your language.
All appearances can be modified if you know css by editing them inside this css file
/modules/mod_poplogin/tmpl/mod_poplogin.css
Hope that helps...
13 years 8 months ago #2 by erwinschro
Thank you for your quick answer. I'll try to make changes. I have another question:
My site has 3 languages spanish, english AND french. If I translate the module how I can assign the module to each language?
13 years 8 months ago #3 by lolaflores
Well that depends on how your multi language site works. If you're using an extension to build a multilanguage site then you should know how they work, by reading a guide from them maybe.
13 years 8 months ago #4 by erwinschro
Sorry again. I´ve translated the module to spanish (I attach the file). I copy the file es-ES.mod_poplogin to folder language/es-ES and I put spanish in the module, but It doesn´t work. Could you help me?
13 years 8 months ago #5 by lolaflores
If you use the single language for your site, you need to setup the global language as Spanish in your global configuration.
But if you want as multi language site works, how do you do that, are you use an extensions for multi language system?
Good Luck
13 years 8 months ago #6 by ronysyz
