jQuery (I guess) conflict
As you can see in test site: nouscatalans.cat/NEW I've installed your module. Immediately, the two other modules that uses jQuery (the Dropdown Mega Menu, and the Pinterest-like articles showcase at the bottom), that were working fine, stop working, and your module doesn't changes the slides as it should. Your module is only in the frontpage, if you navigate wherever you want in the site, the menu works fine, as it does the bottom module.
Furthermore, maybe related, the nivo type only shows a grey placeholder, not any image.
Thanks.
13 years 4 months ago #1 by Artur
It looks like finally you've made them work now...
13 years 4 months ago #2 by erwinschro
Yes. I don't know exactly how I managed it, but it works.
Thanks.
13 years 4 months ago #3 by Artur
