K2 Mini - Image won't go away on article
- Posted by JD (2) Offline
First, K2 Mini ROCKS! Thank you!
I added an image in the K2 Item Image tab so it shows up fine in the module, but now when I go to the article it has that same image covering the article and I can't get it to go away!
13 years 4 months ago #1
by JD
Hi joomlaexcellence, Thank you for your awesome feedback, can you share your website URL so I can take a look?
13 years 4 months ago #2
by andy
Here is the URL: joomlaexcellence.com/ecopeaceful.com
I have also included it in the "Add Reference Link" and the "Your Site Details"
Thanks!
Note: When I first filled in the "Ask A Question" form it asked for a "Your Site Details" which I did fill in.
13 years 4 months ago #3
by JD
Thanks!
We're sorry to say that that K2 item popup image is nothing to do with MiniK2 module. It's related with the your JAT3 blank template feature (a modal box plugin maybe..)
So I will suggest you take a visit to their support forum it might be someone had the same issue like that...
13 years 4 months ago #4
