PROBLEMS with Jquery + speed Nivo slider "Responsive Banner"
- Posted by giggimix (6) Offline
Hello I have problems with jquery too if active "Adaptor Slider".
As an alternative I'm using the Nivo Slider but how do I slow down the speed.
I need to manage a range parameter for each banner.
helppp
new.salentowebtv.tv/
13 years 4 months ago #1
by giggimix
helppp
Hi, I have visited your website and looks like the sliders (you have multiple banners there) are working good.
Regading your problem to slow down the speed, please read this thread :
www.templateplazza.com/support/forum/res...eat,-too-fast-though
13 years 4 months ago #2
by andy
I clicked on the link but there are various threads that what I read?
13 years 4 months ago #3
by giggimix
Ah ok ..... but found I could use to synchronize the banner then give it a different parameter for each
13 years 4 months ago #4
by giggimix
Ok then you will need to modify two files, mod_responsivebannerslider.php and mod_responsivebannerslider.xml
Open the file [ROOT]/modules/mod_responsivebannerslider/mod_responsivebannerslider.php about lines 198 -212 find the nivo code part, change that into like this :
then open the file
[ROOT]/modules/mod_responsivebannerslider/mod_responsivebannerslider.xml
after this code (line 94) :
add this code
No you should be able to configure different slider speed for each module
13 years 4 months ago #5
by andy
$jsinline = "
jQuery(window).load(function() {
jQuery('#slider-".$rbs_mod_id."').nivoSlider(
effect:'".$nivo_effect."',
animSpeed: '".$params->get( 'aspeed', '500' )."',
pauseTime: '".$params->get( 'ptime', '3000' )."',
";then open the file
<field name="nivoformat" type="spacer" label="MOD_RESPONSIVEBANNER_NIVO_DESC" class="text"/>add this code
<field name="aspeed" type="text" default="500" label="Anim Speed" description="Animation Speed"/>
<field name="ptime" type="text" default="500" label="Pause Time" description="Pause Time"/>No you should be able to configure different slider speed for each module
Thank you very much around the screen .... I did well?
I'm trying changing the seconds but it seems the same.
thanks Luigi
13 years 4 months ago #6
by giggimix
thanks Luigi
