Conflict with IceMegaMenu
I just bought Joomla Related article plugin but it has conflict with my menu module which I have on the site the menu is from IceMega Menu for joomla 3 it makes the design ugly and replaces right positions.
I am attaching screenshot for you the website is currently not available for public and I want to request a refund.
thanks
13 years 2 weeks ago #1 by Hamnawa
You can see the screenshot without the menu it appears good here.
13 years 2 weeks ago #2 by Hamnawa
Why did you have a conclusion to get a refund while the module is works without your MegaMenu. You should also think this as a MegaMenu issue. As we can't take a look at what cold be the issue there, we can't help you more.
13 years 2 weeks ago #3 by erwinschro
I have the same problem with rockettheme templates. The problem appear with side panel on (left or right)/ No matter that module placed in side panel - even simple html ...
Then side panel in right position - all content in this panel is dissapear, the in left - the panel is empty and the content appers in main body after Joomla Related module.
Can you fix it?
12 years 9 months ago #4 by Oleg
Hi Morphina
How can we help you on this? at least you can setup a temporary page URL for us so we can take a look at the problem.
12 years 9 months ago #5 by erwinschro
I'm not familiar with css but it seems the problem in "moz-box-sizing" - see attach.
All fine then i remove check in rules.
12 years 9 months ago #6 by Oleg
