modual position
Is it possible to squeeze a modual position in between the k2 deals and joomla daily meals where the x is see attached?
It would be good if I could have the template that would have 1 wide column and then 2 thin moduals
13 years 3 months ago #1 by matthew
Matt
Honestly I'm not clear on what you're trying to get.
But I'm 100% sure that any change that you want, it needs a lot of work to get done.
Again we're so sorry if we can't help you with all such a custom template work. that's beyond support can give to you.
13 years 3 months ago #2 by erwinschro
I want to have the layout like the 3rd template see attached because the
Buy
value discount you save
k2 area takes up to much space is it possible to have it like see attached displays
eg; cell_4a and cell_4b would be the k2 area and cell_4c cell_4d would be moduals
is that possible
13 years 3 months ago #3 by matthew
13 years 2 months ago #4 by matthew
