Many errors from DealPlazza Template
I bought the DealPlazza template and below errors
1) Item can't be linked to Virtuemart properly.
When I clicked "Buy" button at below page, the product page cannot be shown properly. The page has no design, my product name becomes error code, the qty cannot be changed and there has no "Add to cart" button.
mb.crispypark.com/mb/item/1-50-off-at-deliciousushi
2) It comes out an error page (500 - Display edit_baseurl is not found.) when I tried to check A/C maintainance and Order Status.
Please kindly assist to resolve it asap. Thank you.
Also can I keep Virtuemart function as I would like to provide selection (e.g. size, colour) to my customer. If I can keep more function from Virtumart then this template would be much better.
13 years 4 months ago #1 by hkmegabuyer
First of all, have you read the documentation on how to set them up? I believe it would be helpful for you and also there's a quickstart package that you can install at your localhost and learn from it on how everything are set up. Can you take that path first?
13 years 4 months ago #2 by erwinschro
