Poplogin start automatically on pageload
Thanks for thie poplogin extension it looks great! I just have one question which hopefully you can help with ... How can I make poplogin trigger (popup) automatically when a non-registered user or guest visits my site? thank you!
13 years 11 months ago #1 by goody
Hello goody,
Thanks for your feedback
But Unfortunately there is no such function at the moment. We're sorry
13 years 11 months ago #2 by ronysyz
Hi goody,
IMO I don't think that "popping up the login form when non-registered user visiting your website" is a good idea. It can be very annoying :) Why you want to do that?
13 years 11 months ago #3 by andy
Its a business website not available to the public, so people visiting the site have to login or register before they can access the rest of the website once they have it goes away. I liked the idea of a semi-transparent view of the website underneath the login so visitors can have a glimpse but not actually use it until they have signed up or logged in.
otherwise yes it would be really annoying lol
13 years 11 months ago #4 by goody
Ah I see, but I think it's still not a good approach to use javascript as a content protection, because visitors can bypassing it by disabling javascript on their browser. I'd rather to suggest you to apply this kind of protection in the template level :)
13 years 11 months ago #5 by andy
sounds like a plan, thank you :)
i'll give it a go!
13 years 11 months ago #6 by goody
