deal plazza faulty
I purchased deal plazza and installed quickstart with sample data, But it is faulty.
See mackbuy.com
I did installation as usually and as is written in document... I am experienced installer...
13 years 4 months ago #1 by E V
It's a folder/file permission problem so these files are not loaded properly :
mackbuy.com/templates/deals_plazza/js/template.js.php
mackbuy.com/templates/deals_plazza/css/template.css.php?v=1.0.0
Please try to change permission of the folder (including all sub folders and all files inside it): mackbuy.com/templates/deals_plazza into something executable or writable (644 or 755)
13 years 4 months ago #2 by TemplatePlazza
With 755 it solved. THANK YOU SO MUCH!
13 years 4 months ago #3 by E V
