mini k2 masonry.js problem
- Posted by xristos (9) Offline
i have a problem probably with jquery and mini k2. i get an error on chrome console
Uncaught TypeError: Object [object Object] has no method 'imagesLoaded'
about masonry
tried to disable jquery load but still the same problem
domain is tips.net46.net/
any suggestions please???
13 years 1 month ago #1
by xristos
about masonry
Mmm I'm not not sure why that happen. First can you disable jQuery library from being loaded from slideshowck module and see if that make any difference?
13 years 1 month ago #2
i disable jquery but i left jquery easing enable in slideshow ck mod and problem dissapeared. thank you very much for your help.
13 years 1 month ago #3
by xristos
after disabling jquery from slideshow ck gallery seems too slow and not renderig images properly....can we find another solution ??
13 years 1 month ago #4
by xristos
Hi, have you managed to solve the problem? because looks like your website works properly now
13 years 1 month ago #5
by andy
- Posted by Rolando Murillo (1) Offline
I hate when Masonry does that, maybe you can try Salvattore, it does the same thing but it doesn't use fixed values with each column so the images don't need to load before the script. Plus you can set everything up with CSS and HTML.
salvattore.com/
13 years 1 month ago #6
by Rolando Murillo
salvattore.com/
