problem !not show the banner completly
I have downloaded Carousel Banner module,& the module does not show the image completly.After that i click on my firebug icon,it works properly.But when i refresh the page,the problem remains.My site is on wampp server.
Also it doesnt show the second image.
Thank You all
13 years 4 months ago #1 by axiom
It probably a multiple jquery issue, please make sure only one jQuery called by your website.
13 years 4 months ago #2 by TemplatePlazza
thank you.I got what u mean.but can u tell me exactly how to do it?
I have used modules that every one will call its jquery,& i dont know how to fix that issue.
I have another problem,i made 3 banners,but the module just show one image
Thanks for ur help
13 years 4 months ago #3 by axiom
For the carousel banner, you can disable the jquery load by disabling it from the module backend. Other extension should have similar option on their backend too
13 years 4 months ago #4 by TemplatePlazza
thankyou
but i didnt have this field asking: load Jquery?
can u tell me another way?eg deleting Jquery library from its folder is possible?
13 years 4 months ago #5 by axiom
Find this option at Carousel Banner parameter page
13 years 4 months ago #6 by TemplatePlazza
