DealPlazza Quickstart installed but template frontend not working
DealPlazza Quickstart installed OK but when view frontend the template appears all unstyled and there is a message -
"Your template does't have jQuery lib installed. Please enable jQuery from the module backend parameters to make it work".
13 years 3 months ago #1 by Brett
We can't access your site but from the error it looks like there's file permission problem especially for the template folders and files. Can you manage to make them writeable first?
13 years 3 months ago #2 by erwinschro
Thanks. Works now. For some reason when unpacked (zip file) the template folder got permission of 700.
13 years 3 months ago #3 by Brett
