Xtypo Parameter Settings
  • Posted by Michael Fitzpatrick (1) Offline
I have been using xtypo version 1.4 on a joomla 1.5 site. The site has just been rebuilt in joomla 2.5 and I have installed the current version of xtypo, which is very easy to install but seems now that there are no "Parameter settings" that were were available in the 1.4 version.
Is it possible I have not installed correctly or is there a commercial version with these settings available?
13 years 11 months ago #1 by Michael Fitzpatrick
Hello Lotus7,
great thanks to always using xtypo :)
and about your question, that's right, in the new version, we have removed those parameters and if you want to change the color, you can edit the css files of enabled theme
Good luck
13 years 11 months ago #2 by ronysyz
Hi lotus, Yes we have removed the custom styles in the parameters setting and replace it with the "theme" function. We think it will be more effective to use theme rather than modifiying css styles in the backend. We also will release the Xtypo 3 this week with some useful new features, so please stay tune ;)
13 years 11 months ago #3 by andy
