RBS - Sequence javascript won't load (JQuery problem)
- Posted by Jaakko Haavisto (4) Offline
I got problem with Responsive Banner Slider. Nivo works fine but Sequence has this weird problem. It doesn't work when I'm loading JQuery from elsewhere. I'd like to use JB library (www.joomlabamboo.com/joomla-extensions/j...joomla-jquery-plugin) to load JQuery but when I try to do that, Sequence javascript doesn't load (you can see the outcome from the site). I have also tried JQuery Easy (www.simplifyyourweb.com/index.php/downlo...ory/8-loading-jquery) to load JQuery but the result is the same.
Sequence works only if I let RBS module load JQuery OR i'm loading JQuery at index.php.
Thank you for your time!
13 years 2 months ago #1
by Jaakko Haavisto
Hmm strange, the website doesn't load the file sequence.jquery-min.js. That the reason why the animation doesn't work. Can you try to switch to the joomla default template to find whether this is a template problem or something else?
13 years 2 months ago #2
by andy
Thanks for fast answer!
Now I loaded Beez2 -template and problem persists. I've also disabled my CSS/JSS optimizer and cache. Don't know what to do
13 years 2 months ago #3
by Jaakko Haavisto
Hmm, looks like this is not a template problem, because the file sequence.jquery-min.js still not loaded. Did you install any of specific extension that is related to javascript?
13 years 2 months ago #4
by andy
All that I can think of are jbetolo (JS & CSS optimizer) and JQueryEasy but those extensions are disabled. I even removed those on my local installation but it didn't solve problem.
Here are my all extensions: dl.dropboxusercontent.com/u/15760416/plugins.jpg
It works only if I add jquery to index.php or I use module's own JQuery. Those options won't fit my situation
13 years 2 months ago #5
by Jaakko Haavisto
Hmm there's too much external extensions you have that I don't know how to track it. The problem is just because the file sequence.jquery-min.js is not loaded and I don't know what extension that remove it.
By the way, you said you have disabled jbetolo, but from your screenshot, it's a component. How did you disable it?
13 years 2 months ago #6
by andy
