miniFrontPage not showing thumbs when cache enabled
Hi, when I have enabled cache on the core Joomla! 3.0 system the thumbs not showing, although some are showing from the imagecache of mFP .. when I check the image not showing path it has a missing "/" between the images folder the image filename itself. How to solve that problem?
albahrainnews.com
13 years 2 months ago #1 by Hasan AlDoy
Can you point us which part in that site that images thumbnails don't show up?
13 years 2 months ago #2 by erwinschro
Actually it shows most of the times, I tried several browsers and OS's the behavior is the same, when cache is disabled everything is normal through.
The only parts where mFP is used is the banner from under the slider, and the 2 small banners on the left sidebar, as shown in the photo attached the banner with the guy on the right thinking:
13 years 2 months ago #3 by Hasan AlDoy
ooh when cache is enabled right? we're not sure about that and can't give you a solution for now. We need to take a closer look on it and can;t promise you anything. Anyway, thanks for your report on this issue.
13 years 2 months ago #4 by erwinschro
